2000 Dodge Durango Clutch Fan
141,779 MILES • V8 • 4WD • AUTOMATIC
CHANCES44
Hi, I am told I need a cluctch fan since the blades are loose. Do I need a clutch fan and an electrical radiator fan? Someone said I don't need both. How long / much to replace the clutch fan with a rebuilt one? Is there such a thing? It seems to be one thing after another now.
Thank you in advance,
Brenda
Jan 4, 2010 at 8:57 AM
MARKIE777US
  • 14 POSTS
it is kinda tricky but if the bolts on the back of the fan are loose then they just need tightened, however if they are tight then most likely it's the bearings in the clutch of the fan and does need replaced, i wouldn't recommend using an electric cooling fan unless factory installed. where i live the clutch costs around $60.00 to $70.00.
Apr 11, 2020 at 9:04 AM
