1999 Dodge Durango coolant
CHERRYBIG
  • 1999 DODGE DURANGO
  • 4 CYL
  • 4WD
  • 134,000 MILES
I notice that my coolant fuel is leaking from my carl when I check to see if my radaitor had fuel in it. It was full and didnt need anything the radaitor is not running hot are anything im trying to see if my coolant resvior have a leak in it when I was putting some coolant in it I noitce it was running out. Do my radaitor needs replace or something else does
Thursday, January 17th, 2008 AT 3:00 PM
BLACKOP555
  • 10,371 POSTS
First of all, you will have to look where the coolant is leaking, start the vehicle and look it all over the place for a leak.
Thursday, January 17th, 2008 AT 7:11 PM
CHERRYBIG
Well it seem like the coolant is leaking from the resvior tank that on the side of the radator because I notice that my coolant tank is empty now. And there radiator is still not running hot and have fuel in it
Monday, January 21st, 2008 AT 1:36 PM
BLACKOP555
  • 10,371 POSTS
In that case replace your tank if you see it coming from the resevoir tank.
Monday, January 21st, 2008 AT 4:15 PM
