Tuesday, February 10th, 2009 AT 7:59 AM
When you first start my truck from cold it shifts into 1st gear ok. When it hits 2nd gear it seems to shift up into over drive mode and the rpms go up until you let off the gas some and then it shift into the gear it should be in. I was just wondering what might be the problem. Could it be a sensor? I am not an automotive person but I cant imagine the transmission is going bad already at 55000 miles. It seems really noticeable when first using the truck fresh off of being cold. If it gets to highway use. It shifts into 2nd gear fine, but seems to stick in the gear until I let off the gas some and then it shifts to where it should be.
