1998 Dodge Durango
MSRILEY1980
Transmission problem
1998 Dodge Durango Four Wheel Drive Automatic
there is noise coming from the transmission,there looks like there is a milky substance in the transmission fluid the transmission is not slipping it is just making a whinning noise
Jul 16, 2009 at 10:37 AM
  • 110,246 POSTS
I need you to check the radiator to see if it looks like there is ATF getting into the radiator. My concern is the radiator has gone bad and the coolant is getting into the transmission. That is what would cause a milky substance, when the two fluids mix. I recommend not driving it until this is checked. The noise could be a bearing going bad in the trans as a result of the coolant thinning the ATF.
Let me know what you find.
Jul 16, 2009 at 3:26 PM
