1998 Dodge Durango Not getting gas
11,700 MILES • V8 • 4WD • AUTOMATIC
SZPARAGA
  • 7 POSTS
I thought my fuel pump was bad, bought a used one,installed it, same poblem. What in the world else could it be? Someone mention a regulator of some sort. I am lost. Is there a switch some place? Where is this cam regulator located, if thats what its called, some kind of sensor. HELP! Thanks to anyone with a good answer or possible solution. Blessings
Sep 8, 2008 at 2:32 AM
OBXAUTOMEDIC
  • 3,716 POSTS
[quote:b63fa53d8e="szparaga"]Engine Performance problem
1998 Dodge Durango V8 Four Wheel Drive Automatic 117,00 miles
I thought my fuel pump was bad, bought a used one,installed it, same poblem. What in the world else could it be? Someone mention a regulator of some sort. I am lost. Is there a switch some place? Where is this cam regulator located, if thats what its called, some kind of sensor. HELP! Thanks to anyone with a good answer or possible solution. Blessings[/quote:b63fa53d8e]
Have you checked the Fuel Pump Relay/ It is located in the Power Distribution Box under the hood. One way to check if it is bad is to look at numbers on relay and match up with another relay in box, if find match pull that relay and place it in the slot for the Fuel Pump relay try starting. If starts replace relay with new one.
Sep 8, 2008 at 2:41 AM
SZPARAGA
  • 7 POSTS
Is that the fuse box you are referring too??
Sep 8, 2008 at 3:59 AM
LYNN75
  • 10 POSTS
Blown fuse maybe??
Sep 8, 2008 at 6:43 AM
OBXAUTOMEDIC
  • 3,716 POSTS
[quote:f83dfc44da="szparaga"]Is that the fuse box you are referring too??[/quote:f83dfc44da]
Yes, it is. there are fuses and relays in it...
Sep 9, 2008 at 7:35 AM
