easy way to change fuel pump filter
2002 DODGE DURANGO
FIRERATT68
is there a trap door in the back to get to the fuel pump without taking the tank off?
Jan 13, 2010 at 7:50 AM
BLUELIGHTNIN6
  • 16,542 POSTS
for fuel pump and/or filter removal, you will have to remove the fuel tank. Here are two guides to help you step by step.
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
and
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
Jan 13, 2010 at 7:55 AM
RICH800
instead of pulling the fuel pump out of the tank when bad can i install a in line electric fuel pump
Mar 30, 2019 at 6:05 AM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
you could but it's more trouble in the end, probably take longer to do this than replace the stock fuel pump. would have to find a fuel pump that not only pushes but also pulls, since it would have to pull fuel from the tank into the pump and then push it onward, all of this having to be done at a specific fuel pressure also. you would also have to relocate all of the fuel pump wiring.
VIPERCALBO
I Just replaced my fuel pump and now it cranks but after running for 20 mins or more. When I turn my durango off it just turns over but doesn't crank. Go back next morning my durango cranks again. Then after 20mins or more of running my Durango will not crank?
HMAC300
  • 48,601 POSTS
try resetting security system may have engaged partially then get it scanned for codes by a mechanic
VIPERCALBO
Thank You I will give your advice a try
RENEE L
  • 1,260 POSTS
It sounds like the battery cables are dirty. here is an article that will help you:
Please let us know what you find so it will help others.
ROBBYSMOM1
car will periodically not start but is not a starter issue, that has been replaced recently - we don't think it is bad gas but for the past 4 days, the car would not start and then this morning, it started immediately and ran fine. This same thing happened 2 weeks ago, one minute it was running fine - then turned it off and when attempted to start again, it wouldn't and then a couple of days later - it was fine. does that sound like fuel pump? Car also has new battery.
BLUELIGHTNIN6
  • 16,542 POSTS
could be..next time won't start try knocking on the fuel tank. this will jar the fuel pump and if pump is faulty , this will almost always cause the pump to start again.
Next time it happens-don't wait for nothing-do below to determine if its fuel or spark issue.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
RANDY3357
have a 1998 dodge durango, keep stalling out, it is worse when it is cold after warms up, its better. have replaced the fuel pump. could it be a vauum from a gasket?
WRENCHTECH
  • 20,761 POSTS
You may have a bad IAC ( idle air control) but try cleaning the throttle body first. Remove the intake snorkel, have someone hold the throttle wide open for you and scrub the back side of the throttle plate and surrounding bore with an old tooth brush and some carb cleaner. Be sure to spray some into the small holes next to the throttle plate. That should help stabilize the idle. If it still has a problem, replace the IAC.
CHRISREAVES
it needs a fuel pump but ended up going out to get a new pump with the gas tank too...so now i took the straps off to loosen the tank. How do i get to the hoses thats connected to the tank and if its hard to do how do i remove the fuel pump without the hassle of the gas tank
Dec 18, 2019 at 2:24 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
support tank and drop down to gain access to top hoses and line to disconnect
doing tank or pump ,tank must come down
good luck
LISA PAGEL
How difficult is it to replace a fuel pump? where is it located? estimated costs at an independent repair shop?
Dec 18, 2019 at 2:25 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
its in the fuel tank
not an easy think to do
over $500
SERVICE WRITER
  • 9,123 POSTS
Yeah they are pricy..I prefer to use the oem brand on them. they have the regualtor, pump and sending unit all rolled into one.
Unknown factors will be the strap and line issues.
Independents use differnent pricing matrixs, talk to them about the cost first.
2CP-ARCHIVES
  • 4,540 POSTS
Hi guys,
How do you know for sure if you need a fuel pump? Do you know a fair price for the cost?
SATURNTECH9
  • 30,869 POSTS
Which engine do you have?Also what are the symptoms?Any codes in the computer?Have you checked the actual fuel pressure?
TRISH D
  • 5 POSTS
Thank you for your quick response. It cranks about 4-5 times in the morning. It is at the dealer and they are thinking the fuel pump. I have the small V-8 - 5.9. 2WD. They are suppose to do a diagnostic test, but can't find the problem yet.
SATURNTECH9
  • 30,869 POSTS
Does it only do that first thing in the morning?Have they checked for the fuel pressure bleeding down yet?
TRISH D
  • 5 POSTS
Good Morning Saturntech9, well I found out yesterday that they did check the pressure, and it is the fuel pump. Could it possibly be anything else? It is only does the problem in the morning. Any advice where I could get it repaired at a reasonable price? The dealer charges a crazy amount. Thanks again!
SATURNTECH9
  • 30,869 POSTS
Did they see the pressure bleeding down is that why there saying the pump is bad?Also what is your zip code so i can see where you can take it and prices.
TRISH D
  • 5 POSTS
Yes, I believe it did bleed down, and my zip is 90630. Thank you again for your help, you are the best!
JUSTICE08
I am wondering how you diagnose a fuel pump. My fuel pump in my durango doesnt make any noise when its cold but when it warms up it makes a loud noise(kinda like a humming noise). The other day my wife said that everytime she let off the gas it would die out. No check engine light ever came on. It was very cold that day and she was at a quarter of a tank. We where told that before the fuel pump goes out it will make noises. Also is it possible that because she was she low on gas that there could of been some condensation in the tank and that could of caused the stall out? If not how do i go about replacing the fuel pump?
BLACKOP555
  • 10,386 POSTS
yes if there is water in the tank it can be sucked up when the tank is ran low.
but other then that i dont think it would cause the car to stall out if the accelerator wasnt being depressed.
when you say that the pump is quiet when cold but gets loud when its been ran a while then it sounds to me like your pumping is showing its age, to check to be sure you would have to perform a fuel pressure test on the fuel rail.
to change the pump the tank has to be droped by disconnecting the fuel fill hose and then putting a jack under then tank and loosening the straps then disconnecting the hoses and wires and then dropping it the rest of the way.
SATURNTECH9
  • 30,869 POSTS
I have 596-814 in your area for a fuel pump replacement.
OLDTECH2
  • 64 POSTS
My 2000 Durango always has a hum in the back from the fuel pump. Cold or hot. It's always struck me as a little noisey, but it's never been a problem in about 125,000 miles.
The dieing at idle sounds to me like an idle validation issue in the tps. I've seen other Dodges have tps problems and not set codes.
The other option would be that the pump is dieing and dropping pressure. However, that should cause a problem under acceleration, not at idle. Note: the pump uses fuel for cooling, so it's possible that fuel level could cause the pump issue. (GM trucks have the problem and are notorious for the pump dieing due to cooling issues.)
You mentioned water in the fuel. While this can shut the engine down, it will normally misfire and generally run bad before that happens.
KRISTY WIGGINS
Were is the automatic shut off is located
HMAC300
  • 48,601 POSTS
it's a relay in the power dist box underhood it's called a ASD relay
WRENCHTECH
  • 20,761 POSTS
If you are referring to an Inertia "collision" switch, it doesn't have one. That is a Ford feature.
