truck won't start. I need help
BIGBRYAN
Truck was running fine yesterday. Today i went out to start it and it would kick over. Timing belt is ok, plugs,wires, cap, distributor, battery, are all okay. Fuel pump turns on. Relays are ok. There is the postive and negative cable that come connect to the battery as well as another cable that goes to the relay box. This cable has been spliced and reconnected. Could this be the problem? that connection seems very loose and you can see it is starting to disconnect. 92 dodge dakota sport v6 auto
Feb 22, 2007 at 4:03 AM
CHEVY22
  • 1,375 POSTS
i would def fix anything obvious first ,make sure you unhook the battery before making any repairs on main harness and get back to us after that is done
Feb 22, 2007 at 4:18 AM
BIGBRYAN
i fixed the wire harness and still no luck. Kinda stumped at this point. The only other option would be the fuel filter but i replaced in within the past year. I'll check that out tomorrow morning. any other suggestions? thanks
Feb 24, 2007 at 3:03 AM
