1997 Dodge Dakota Lug Nuts Coming Loose
CATFISHCHAD
I have a 1997 Dodge Dakota 4x4 extended cap with 75,000 miles on it and i just got some new rims eagle racing rims to be exact and i got it home from goodyear tire place and i have had it for like a month and after 2 weeks the lugnuts came loose soo i didnt think anything of it so i tightend them and like a week later they cam loose again....and to make a long story short my lugnuts on my back wheels keep coming lose any help
Chad
Jun 9, 2006 at 3:11 PM
CARAVANOGRE67
  • 22 POSTS
on your truck the lugs should be torched to 100 ft pounds if they keep coming loose go to your auto parts store and purchase some lock tight blue put a little bit on your studs and tighten to 100 ft pounds you could also check and see if they put standard nuts on a metric bolt or visa versa :D
Aug 2, 2006 at 5:48 PM
Suggested Repair
Torque the lug nuts to 100 ft-lbs. If they loosen again, apply a small amount of blue thread locker to the studs and retorque to 100 ft-lbs. Also verify the nuts match the studs and are not a standard-versus-metric mismatch.
Conversation Summary
The owner of a 1997 Dodge Dakota says the rear lug nuts repeatedly came loose after new Eagle racing rims were installed. The expert recommends torquing them to 100 ft-lbs, using blue thread locker on the studs if they loosen again, and checking for mismatched standard and metric nuts and studs.
