1993 Dodge Dakota Tired of Shotgunning
1993 DODGE DAKOTA
212,000 MILES • 6 CYL • 2WD • MANUAL
DENKOO_CHIKARA
  • 6 POSTS
The truck seems to run fine till it I reach highway speeds then starts to stall after it starts to stall it stalls in all gears after searching mutiple fourms i did the stupid thing and started shotgunning because it wasn't throwing any codes so so far I have replaced the following a few are unrelated I think but mentined anyway just in case and tested map sensor responded as it should
water pump
hoses
thermostat
coollent temp sensor
egr valve
pcv valve
plugs
wires
cap
rotor bug
coil
o2 sensor
tps
From what i read im down to pick up coi/distrubitor,l asd relay, or fuel pump
am I right in thinking this, and is there a way to test the above. I am running out of shells
Sep 13, 2010 at 4:18 AM
Start by checking the fuel pressure, fuel pump could be on its way out
Sep 13, 2010 at 4:23 AM
DENKOO_CHIKARA
  • 6 POSTS
Thanks I have a friend who has a tool to check will reply tomorrow with result
Sep 13, 2010 at 4:58 AM
I'll be waiting we move from there
Sep 13, 2010 at 5:07 AM
DENKOO_CHIKARA
  • 6 POSTS
tested pump with regulator pressure was where the book says it should but I have never had an issue with it at idle did go ahead and replace relay still does it also check splice 115 cause I read it could cause issues but it was clean so am not sure where to go cause I think it could still be the pump but also the distributer what do you think and could it be caused by something else
Sep 14, 2010 at 8:36 AM
Did you check the fuel pressure if so what was the readings
Sep 14, 2010 at 8:40 AM
DENKOO_CHIKARA
  • 6 POSTS
31 with vac hose on and 40 with hose off
Sep 14, 2010 at 8:42 AM
The fuel pressure is within the limits-at highway speed when it stalls does the engine actually stops or just a severe hesistation and picks up again?
Sep 14, 2010 at 8:51 AM
DENKOO_CHIKARA
  • 6 POSTS
when it starts to stall it is a complete loss of acceleration if I leave my foot off the pedal I am able to bearly apply pressure and it will gradually accelerate but if I apply to much it continues to decelerate
Sep 14, 2010 at 9:15 AM
MERLIN2021
  • 17,250 POSTS
Is your check engine light on? If yes turn the key from off to on three times, on the fourth one leave it in the on position, count the flasshes...22 would flash as 2 blinks, then a short puase, then 2 more blinks...if several codes are stored, the pause is longer between codes, code 55 will be the last code...do this and post all codes found...
It sounds like you cataltic converter could be clogged.
check the converter by attaching a vacuum gauge to the intake manifold, leave it running for 5 mins and watch the gauge does it drop? If yes the exhaust is restricted.
Sep 24, 2010 at 2:20 PM
DENKOO_CHIKARA
  • 6 POSTS
I removed the bed removed fuel pump found one of the pump had come off of one of the mounting brackets and was moving withing the tank causing the pump to intermantantly fail replaced pump issue resolved thanks for your assistance
Sep 26, 2010 at 2:11 AM
MERLIN2021
  • 17,250 POSTS
Good work! Your welcome.
Sep 27, 2010 at 1:36 AM
