1998 Dodge Dakota Drive Belt Tension Fix
DRMEANS
Can anyone tell me where/how to tighten the drive belt on a 1998 Dodge Dakota 4X4 Sport.. Or can anyone tell me where to find a drawing of how to tighten it?? Thanks in advance...
DRM
Apr 3, 2006 at 10:40 AM
LOSONE
  • 1,616 POSTS
The drive belt is automatically tightened by the belt tensioner. It looks like it has a pivot so it can be moved with a socket wrench. It probably is bad and needs to be replaced along with the belt.
The belt diagram is usually on the area in front of the engine or uder side of the hood.
Apr 3, 2006 at 10:45 AM
Suggested Repair
The drive belt is automatically tensioned by a spring-loaded tensioner that pivots and can be moved with a socket wrench. If the belt is loose, replace the worn tensioner along with the belt. A routing diagram is typically on the front of the engine or the underside of the hood.
Conversation Summary
The owner of a 1998 Dodge Dakota 4x4 Sport asked how to tighten the drive belt or where to find a diagram. An expert explained that an automatic pivot-style tensioner tightens the belt and can be moved with a socket wrench. A loose belt usually means the tensioner should be replaced with the belt, and the routing diagram is often on the front of the engine or under the hood.
