1999 Dodge Dakota Tighten Drive Belt
95,000 MILES • 6 CYL • 2WD • MANUAL
BIGFOOT02
I repaired my thermostat that was locked up. In doing so my drive belt was loosened. For the first time in my life I can not find how to tighten my belt on a vehicle. What do and where do I loosen the whatever to tighten the belt?
Tom Godwin
Feb 3, 2009 at 1:57 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Your vehicle is equipped with an auto-tensioner. No adjustments are required. If belt is loose then belt probably has stretched. Auto-tensioner may have failed but that is not too common.
Thanks for using 2CarPros.com!
Feb 3, 2009 at 2:31 AM
