My blower motor does not work. I have removed the motor and jumped it to the battery and it works fine. All the fuses checked out ok. I also checked the wiring harness plug which has power. I am assuming that the switch grounds the hot lead to the motor. Could it be the switch or a resistor that may not be functioning properly? I don't have a wiring diagram to see where the resistor would be. Would anyone know where it might be located?
Oct 11, 2008 at 4:58 AM
