1999 Dodge Dakota Stalls after start
MYREALNAMEISLARRY
  • 1999 DODGE DAKOTA
Engine Mechanical problem
1999 Dodge Dakota 6 cyl Two Wheel Drive Automatic
i just bought this truck 1 month ago, it was running fine then the snow storm hit. Now when it starts it putters out if I dont give it gas. When I try to change gears it also stalls. Some have told me this is water in the gas, I put some fuel cleaner in it and filled the tank. Same problem. It will start then stall.
Monday, December 28th, 2009 AT 5:17 AM
  • 109,936 POSTS
HAs the check engine light come on? It sounds like you need a general tune up. If the wires are old, it will cause it to miss bad enough to not run.
Let me know about the tune up and light.
Tuesday, December 29th, 2009 AT 4:17 PM
MYREALNAMEISLARRY
Turns out I needed to put in some Heet to clean out the water in the gas. Still stalls out if I go ever 4.5 rpms but other than that fine. Thank you
Thursday, December 31st, 2009 AT 4:05 PM
