Hi my dodge truck dies on the road (no buss) hade it towed, it started
Monday, June 7th, 2010 AT 2:54 PM
MECHANIC
The "no buss" indicates there is a break down of communication between the computer and its components. Check for loose wiring in the wiring harness that plugs into the PCM or corrosion that could be causing a problem. Most times, it is a loose wire.
