1998 Dodge Dakota Heater doesn't blow hot
1998 DODGE DAKOTA
13,300 MILES • V8 • 4WD • MANUAL
GRIEGO14
My 1998 dodge dakota does not blow hot air when I turn on the heater. Also, the A/C doesn't blow cold. For the heater I've heard it could be the thermostat or flushing the heater core might work, which is easier. Is the A/C problem related to the heater problem? Can you help me out with this. Thanks.
Dec 10, 2008 at 6:17 PM
JAMES W.
  • CERTIFIED EXPERT
  • 2,394 POSTS
I would try changing thermostats first. It could be a quick and cheap fix. If that doesn't do it, it could be plugged heater core and flushing may help. As far as the a/c, it may just be low on freon. You can buy a recharge kit at any parts store, but there are a couple of tests you should try first.
Dec 10, 2008 at 6:27 PM
GRIEGO14
Thanks - I will try replacing the thermostat. How do you flush the heater core? Also, how do you add freon? Thanks for your help
Dec 12, 2008 at 12:15 PM
JAMES W.
  • CERTIFIED EXPERT
  • 2,394 POSTS
Not knowing what part of the wourld you're in or how cold it is, but what works good is disconnect the heater hoses from the engine(not the heater core) and use a regular garden hose. Or, you can use an air hose, blow it out, add some water to the hoses and blow it out again. You can do this several times, BUT,--you have to be careful with air so you don't blow up the heater core. On adding freon, if you buy a 134 recharge kit, it will come with instructions. Most important is to be sure you are on the correct hose for charging.
Dec 12, 2008 at 4:44 PM
