1998 Dodge Dakota
CONG
  • 1998 DODGE DAKOTA
  • 4 CYL
  • 4WD
  • MANUAL
  • 200,000 MILES
There is a leak in the interior passenger side under the carpet I would like to know where it maybe coming from and do I need to have it checked right away
Tuesday, May 26th, 2009 AT 8:58 PM
CARADIODOC
  • 34,364 POSTS
Suspect a plugged rubber drain tube for the air conditioning. Look under the hood, on the firewall, just right of center. It's a right angle rubber tube, about four inches long, and is held on with a springy wire ring. Squeezing the ends of the ring will allow it to be pulled off. Sometimes you only have to squeeze the tube to release debris stuck inside. Water might come rushing out too. If nothing comes out, remove the tube, then carefully stick a pencil into the plastic spout to dislodge anything that might be stuck in there.
If you don't have air conditioning, suspect a leaking heater core. The leaking fluid will smell sweet, and the level will drop in the radiator or overflow reservoir. This will also cause the windshield to fog up on the inside when using the defroster. If that doesn't appear to be the problem, there could be a leak around the windshield, but this is only common on Ford trucks.
Caradiodoc
Thursday, May 28th, 2009 AT 12:23 AM
