1995 Dodge Dakota Truck stops running
DFOSTER55
  • 1995 DODGE DAKOTA
  • 6 CYL
  • 4WD
  • 14,300 MILES
I can be driving down the road and the truck will quit running. I stop, put the truck in park and turn off the engine. Wait a minute and turn the key and it will start. I go down the road and it quits again. Can you help me figure out what the problem could be?
Thanks
Deborah
Wednesday, April 15th, 2009 AT 5:06 PM
Check the fuel pressure to rule out a failing fuel pump and also test the power input to the coil/coil packs, distributor pick-up coil, ignition control module, ECM, Ignitor cam and crank sensors-
Wednesday, April 15th, 2009 AT 5:37 PM
