1995 Dodge Dakota No Fire
JRODBUSTER1
  • 1995 DODGE DAKOTA
  • V8
  • MANUAL
  • 170,000 MILES
Cranks good, but no fire. Changed the coil and the ECM and had no luck. Checked grounds.I'm stuck and need this truck, its been down for months and im on a fixed income and cant keep guessing. Can you help me?
Tuesday, March 30th, 2010 AT 7:57 AM
Did you have a check engine light come on or has flashed prior to this problem and when was your last tune-up?
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Tuesday, March 30th, 2010 AT 6:39 PM
