Oil pan removal
1995DODGE
  • 1995 DODGE DAKOTA
V8 four wheel drive automatic.
How to remove oil pan?
Monday, December 28th, 2009 AT 4:39 PM
See below: Sorry no diagram.
1. Disconnect battery ground cable, then remove oil dipstick.
2. Raise and support vehicle, then drain engine oil.
3. Remove front drive axle, exhaust crossover and transmission lower cover.
4. Remove oil pan and gasket.
5. Reverse procedure to install. Apply in corner of cap and block. Tighten attaching bolts to specifications.
Monday, December 28th, 2009 AT 10:07 PM
MICHAEL RODGERS
Nobody says anything about the cross-member that is under the oil pan that cannot be removed.
Thursday, July 5th, 2018 AT 11:21 AM
STEVE W.
  • 15,314 POSTS
There is room enough to get the pan out, you may need to pull a motor mount bolt and raise the engine some but it can be removed.
Sunday, July 8th, 2018 AT 4:58 PM
