1992 Dodge Dakota starting
DNJRR
  • 1992 DODGE DAKOTA
  • 6 CYL
  • 165,000 MILES
Performed a compression test one plug wire/plug at a time (only one wire off at anytime.) Now it will not start. Have good spark from coil.
Monday, July 20th, 2009 AT 3:42 PM
CEMENT HEAD
  • 38 POSTS
Try taking out the number one cylinder plug put finger over plug hole have someone crank the engine but do not start, when the #1 cylinder reaches TDC (top dead center) you will feel the air push your finger away from the hole. Now mark your distributor cap verticalyl with a pen to where the cap sits on distrib. And pull off cap, the rotor should be facing the # 1 cylinder. This way you know your timing is correct but also sounds like some how some way a wire or two got mixed up
Monday, July 20th, 2009 AT 8:46 PM
