1989 Dodge Dakota Stalls when I turn right
MRPEPPA
  • 1989 DODGE DAKOTA
  • 6 CYL
  • 4WD
  • 70,000 MILES
Whenever I make a turn to the right my engine tries to stall. If I pump the gas while turning I can sometimes keep it running otherwise I have to put in neutral start it and pop into drive again. Thought it was low on gas but when I put 1/4 tank in it seemed to get worse. Any suggestions?
Monday, September 29th, 2008 AT 3:00 PM
  • 109,921 POSTS
Hi:
This is a tough question to answer. First, it could be an electrical problem. (When you turn, a wire moves or grounds.) Is there a check engine light coming on?
Wednesday, October 1st, 2008 AT 9:05 AM
MRPEPPA
Joe,
No on the check engine light. I plan on putting it up on a hoist this weekend and taking a look at it. Think it could be the fuel filter or float in the gas tank?
Andy
Wednesday, October 1st, 2008 AT 12:13 PM
  • 109,921 POSTS
Anything is possible. To me, however, it sounds like it's electrical. When you have it in the air, check for broken or skinned wires. I feel (without looking at it) that something shorting out when you make a turn. Don't just check the fuel system, look under the hood at the ignition system (coil, distributor.)
Let me know what you find.
Wednesday, October 1st, 2008 AT 1:47 PM
