1988 Dodge Dakota electrical problems
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
RRUSSJR
Recently replaced the battery, I was told by my son that before this that the dome light went out and fuse was still good(For no apparent reason). The truck was running fine. He had a radio installed (he could not get it to work)and the tech told him that he had "some" electrical" problems, do not know what kind.
He came home from school and the truck would not turn over at all, the lights would not come on and there were a few lights on the radio that were illuminated(this without the key in the ignition). As soon as you attempted to turn the lights on, the lights on the radio went off.
The few lights(outline lights only) on the radio are all that works at this point, any suggestions?
Oct 15, 2008 at 4:20 AM
JNOVACK
  • 723 POSTS
if radio was not installed with proper wiring kit it can cause electical probblems these kits cost about $10.00 and is made for each individule vehicle and you need to be follow to the letter, remove radio and see if electric comes back and let me now I will help from there. Thank you
Oct 15, 2008 at 5:25 AM
