2002 Dodge Grand Caravan Turn Signals
BOUJAI1
I have a 2002 Dodge Grand Caravan with 135,000 miles. The turn signals are very eradic. Sometimes they work, sometimes only one side works, sometimes I turn the left turn signal on and the right turn signal is activated and vise versa. Sometimes they don't work at all. Occasionally, I can flip the turn signal arm up and down a few times and it corrects the problem, but not always?
Any ideas?
Thanks for you insight.
Nov 1, 2007 at 7:19 AM
  • 75,988 POSTS
Might want to check the turn signal switch could be shorting out internally and the flasher unit.
Nov 1, 2007 at 12:05 PM
Suggested Repair
Inspect the turn signal switch for an internal short and check the flasher unit.
Conversation Summary
The owner of a 2002 Dodge Grand Caravan reports erratic turn signals that sometimes fail, work on only one side, or activate the opposite side. Wiggling the stalk sometimes temporarily corrects it. The expert suggests checking the turn signal switch for an internal short and inspecting the flasher unit.
