I replaced a left tail light assembly and now the left turn signal and flasher do not work. The front left turn signal blinks very fast. I replaced the bulb, but that did not help. I am not sure if the turn signal worked before because the light has been broken for a long time.
SPONSORED LINKS
Saturday, January 10th, 2009 AT 12:44 PM
BMRFIXIT
MECHANIC
Make sure you used the correct bulb in the right place (rear )
and if so check ground wire
(rear)
Saturday, January 10th, 2009 AT 2:07 PM
BCOMDOHR
MEMBER
I have the correct bulb so how do I check the ground?
SPONSORED LINKS
Saturday, January 10th, 2009 AT 3:25 PM
BMRFIXIT
MECHANIC
Use a test light connected to a known good power and or use voltmeter
at the bulb socket u should have power and ground
if not check the wire of what missing
