1998 Dodge Caravan Engine Squeak
SCOTS_TIGGER
Dodge Caravan - 1998/137347 miles. For the past month now, our engine is emitting a squeaking noise. It first started lightly and only until the engine warmed up. Now it's doing it all the time, mostly when you step on the gas (it quiets down when you take your foot off the gas), and it's louder. It's not the fan belt, but the sound is similar. Help!
Jul 25, 2006 at 7:09 PM
VANDRAGON
  • 298 POSTS
it's the tentioner pully, idler pully or water pump.
Jul 25, 2006 at 11:23 PM
WIZARD7601
try turning off the air conditioner before starting and see if it still squeaks mine also squeaks but when i turn off the a/c it stops dont know why though good luck
Sep 20, 2007 at 3:39 AM
Suggested Repair
Inspect the belt tensioner pulley, idler pulley, and water pump, since the squeak is belt-like and changes with throttle. Also test with the air conditioner off to see if the compressor or its clutch is involved.
Conversation Summary
A 1998 Dodge Caravan with about 137,000 miles developed an engine squeak that began only when warm and now occurs constantly, especially under acceleration, and quiets when the throttle is released. The owner says it is not the fan belt but sounds similar. An expert suggested the tensioner pulley, idler pulley, or water pump. Another user suggested starting with the air conditioner off, noting their similar squeak stopped when the A/C was off.
