1993 Dodge Caravan Humming Noise
LEOPOLDOROZCO
My '93 Dodge Caravan 3.0 lately started making a humming noise accompanied with a slight vibration perceptible after 40 mph at the steering wheel, both disappearing below 40 mph.
The sound seems to come from the passenger side axle. As soon as this noise came on, the inner side of the front tires started to show signs of wear, so I took it to the shop to check the alignment that was done a couple months earlier, the computer showed that the alignment was within the manufacturer's specifications. so, they inspected and re-torqued some bolts, rotated tires etc. in hope that this would solve the problem.
Now, the rotated tires are also showing the same wear pattern.
I'm sure the humming sound, vibration and tires wear are related because all appeared about the same time.
Any ideas or suggestions? Thank you.
Jan 27, 2007 at 3:51 PM
CARUNDELL
  • 602 POSTS
[quote:74bd9bb400="leopoldorozco"]My '93 Dodge Caravan 3.0 lately started making a humming noise accompanied with a slight vibration perceptible after 40 mph at the steering wheel, both disappearing below 40 mph.
Any ideas or suggestions? Thank you.[/quote:74bd9bb400]
Hey Leopold,
There is a definite alignment issue and even though the vehicle may be with in mfr specs, its obvious that further alignment adjustments are needed. A good alignment tech can take the wear of the tires into consideration and adjust accordingly. Let us know!
Chris
Jan 27, 2007 at 11:05 PM
2CARPRO JACK
  • 11,533 POSTS
Could be a bad wheel bearing on that side that is creating the extra camber you are talking about. They will also make noise like that.
Jan 31, 2007 at 11:37 PM
CARUNDELL
  • 602 POSTS
[quote:e8cb827377="2CarPro Jack"]Could be a bad wheel bearing on that side that is creating the extra camber you are talking about. They will also make noise like that.[/quote:e8cb827377]
Great point Jack! Though hopefully the tech checked for that! Would also add, given the age of the van, maybe a more closer look at the control arms and bushings should be in order too! As when the vehicle is sitting on the alignment rack it may be in spec, yet under acceleration or normal driving these components may be shifting causing a misalignment!
Chris
Jan 31, 2007 at 11:54 PM
Suggested Repair
Have a skilled alignment tech readjust the front alignment based on the inner tire wear, even if it is within factory specs. Also inspect the passenger-side wheel bearing, control arms, and bushings for wear or movement that could change camber while driving and cause the humming and vibration.
Conversation Summary
A 1993 Dodge Caravan 3.0 developed a humming noise and slight steering-wheel vibration above 40 mph, apparently from the passenger-side axle, along with inner front tire wear. Alignment checked within specifications, and re-torquing bolts and rotating the tires did not stop the wear. Experts suggested further alignment adjustment based on the wear pattern, plus inspection of the passenger-side wheel bearing, control arms, and bushings for play that may appear only while driving.
