2001 Dodge Caravan Rear Spark Plug Access Fix
DRAGO
2001 grand caravan 3.3l w/ 98K. How do I gain access to the rear plugs to change them?
Jun 20, 2006 at 1:22 PM
VANDRAGON
  • 298 POSTS
if you had access to a lift would be nice. if you can pull it up on two sets of car ramps, then you can get under it and almost set-up behind the motor and gain access to the rear sparkplugs. please be very carefull, wearing a minivan for an overcoat is not my idea of a fun day. also go to a parts store and get a sparkplug boot remover or you will messup the wires. as always safety is first....vandragon
Jun 21, 2006 at 3:36 AM
Suggested Repair
Raise the van on a lift or two sets of ramps and work from underneath behind the engine to reach the rear spark plugs. Use a spark plug boot remover so the wires are not damaged, and follow normal under-vehicle safety precautions.
Conversation Summary
The owner of a 2001 Dodge Grand Caravan 3.3L with 98,000 miles asked how to reach the rear spark plugs. The expert said a lift is ideal, or two sets of ramps so the plugs can be accessed from underneath behind the engine. They also recommended a spark plug boot remover to avoid damaging the wires and stressed working safely.
