2000 Dodge Caravan Rear Plug Access
BOBO
How do I access the rear bank of plugs for removal
and replacement.
Jul 20, 2006 at 2:03 PM
VANDRAGON
  • 298 POSTS
if you pull it up on two sets of ramps you can get under it and almost set up behind the engine. but make sure the parkbrake works well and it is stable on the ramps. please be safe, if you don't feel safe doing this take it to a shop. tell them you need to put it on a lift to get to the rear plugs, let them know you know something about how it's done or they will really stick it to ya.
Jul 21, 2006 at 3:07 AM
Suggested Repair
Raise the Caravan on two sets of ramps so the rear spark plugs can be reached from underneath behind the engine. Confirm the parking brake works and the vehicle is stable; if the setup feels unsafe, have a shop access the rear plugs on a lift.
Conversation Summary
The owner of a 2000 Dodge Caravan asked how to access the rear bank of spark plugs for replacement. The expert advised raising the van on two sets of ramps to work underneath behind the engine, with the parking brake set and the vehicle stable, or taking it to a shop for lift access if that feels unsafe.
