1997 Dodge Grand caravan Sport (Sport and Van who are they kidding?)
three quick thoughts
I have a thunk type noise from the front passenger side. My first thought of course was axle. It is not the axle on either side. My next thought was ball joints, and they seem tight, after that i thougt possible bearings in the wheell, and they also appear to be solit. How about the Strut tower plate, I don't know how to check that with out taking it out, can some one explain that to me? Or any other ideas. the thunk only occurs when you hit a pot hole or somethign in the road.
Thought two, Ihave owned lots of chrylers with 3.3 motors and love them. the 3.8 is new to me, what can i expect from it? I notiiced that it is leaking oil, not sure from were. Looks like the front crankshaft seal or possible the oil pan and the axle is throwing it in that direction. Is their any known problems with oil leaks that may point me int he right direction?
Last thought powersttering leaks fluid out of the rack and pinion. Is this a servicabl eitem, or is it pull and replace only.
Thanks Jeff
Thanks Jeff
Sep 26, 2007 at 7:25 AM
