noise in front end
JDRACER89
Hi we have a 96 grand caravan, not sure of the miledge. We havea loud noise in the front end that is quite noticable when idling and driving. We were told this may be the serpentine belt but we are not totally sure. Today there was a lot of green fluid came from the front end( like rad. fluid.) are these linked.
Jun 18, 2007 at 4:42 AM
MIKE H R
  • 3,094 POSTS
have the water pump checked with a pressure check. the bearing could be giving you the noise you are hearing. with the bearing bad it will cause the seals in the water pump to go bad and leak.
Jun 18, 2007 at 9:47 AM
