1999 Dodge Caravan Loud Noise at Speed
1999 DODGE CARAVAN
160,000 MILES • 6 CYL • FWD • AUTOMATIC
CWJ51
Hello
Our Grand Caravan makes a lot of noise once you get past about 10 MPH. I thought the rear tires might be bad and just replaced them, did not do any good. My son believes the noise is coming from the front end.
The noise does sound like low pitched whirring, something that would come from rotating machinery, and it changes pitch and volume with speed changes.
Thanks
CWJ
May 31, 2009 at 7:11 AM
MMPRINCE4000
  • 8,548 POSTS
Start by doing this:
Raise car, put on stands. Grasp tire and push/pull both horizontally and vertically, if any movement then possible wheel bearing, ball joint, tie rod, control arm bushing.
Check CV boots for any signs of leakage or cuts/rips in rubber boot.
May 31, 2009 at 7:14 AM
