engine not starting when key is turned.
JEFFNKAREN
Dodge Grand Caravan 2002 V6 125,000miles. Problem has been going on probably 2-3 months. Put the key in the ignition and nothing happens but a click. The radio comes on and all the lights on the dash light up. Battery was old so it was replaced in the last month. That seemed to clear up the problem for about 3 weeks now it is back. After multiple times turning the key it will start. Error message donE comes up. Thanks for the help.
Oct 10, 2007 at 2:05 AM
2CARPRO JACK
  • 11,533 POSTS
When it wont start, use a test light to check for power at the small wire on the starter when cranking. If it has power and no crank then the starter is bad. Also be sure battery cables are clean and tight
Oct 10, 2007 at 9:23 AM
