1986 Dodge Caravan Cranks No Start
BRASS
Hi, my old girl 1986 Dodge Caravan Se 80,000M will not start. It turns over,has power but just keeps cranking over. I have replaced plugs,took air filter off over carb all seams fine. After a while near bottom the nipple will leak fuel. I don't know if this is beacause I have flooded it trying to start it so much or what. Any help would be great it has been sitting for a few months now. Cheers Bryon
Jul 19, 2007 at 12:02 PM
  • 75,988 POSTS
[quote:5bc483337c="Brass"]Hi, my old girl 1986 Dodge Caravan Se 80,000M will not start. It turns over,has power but just keeps cranking over. I have replaced plugs,took air filter off over carb all seams fine. After a while near bottom the nipple will leak fuel. I don't know if this is beacause I have flooded it trying to start it so much or what. Any help would be great it has been sitting for a few months now. Cheers Bryon[/quote:5bc483337c]
Start by looking for spark while engine is being crank over at the plug wires.
No sparky could mean: Bad coil/module/CPS/PCM.
Jul 20, 2007 at 4:58 PM
Suggested Repair
Check for spark at the plug wires while the engine is cranking. If there is no spark, inspect the ignition coil, ignition module, crankshaft position sensor, and PCM.
Conversation Summary
The owner of a 1986 Dodge Caravan says it cranks but will not start after sitting for several months. The plugs were replaced and the carburetor air filter was checked; fuel leaks from a lower nipple after repeated cranking. The expert advises checking for spark at the plug wires while cranking and notes that no spark could indicate a bad coil, module, CPS, or PCM.
