drive belts
HEVICA
how do you change a serpentine belt on a 2000 dodge caravan
Aug 4, 2007 at 6:31 AM
SERVICE WRITER
  • 9,123 POSTS
Make a diagram of the belt before removal.
Loosen the tension at the spring loaded tenionser and slide the belt off that tensioner pully and let the tension off the tensioner. Remove the belt, replace the belt according to your diagram. Pull back on the tensioner again and slip the belt back into place.
Aug 4, 2007 at 6:53 AM
