1996 Dodge Grand Caravan Fan Relay Code
I did find out that the relays must be replaced with a solid state circuit relay from the dealer and both relays must be replaced. The code will also set is the fan has been replaced with an after market fan.
Chrysler and Jeep have been suffering from this problem through the mid and late 90's.
I hope this helps Good luck
Suggested Repair
Have a dealer check the VIN for a fan-control relay recall and replace both radiator fan relays with dealer solid-state relays, not just the one under the driver-side wheel well. Also investigate the short that keeps blowing the radiator fan fuse, and confirm an aftermarket fan is not setting the code. The fan motor itself tested fine.
Conversation Summary
A 1996 Dodge Grand Caravan sets code 35/P1491 for the radiator fan relay circuit. The owner replaced one relay and the fan fuse, but the fuse keeps blowing and the code returns after resets. The driver-side fan runs with the heat on and the motor tests good, while the temperature gauge does not rise. The expert noted multiple fan relays, a possible Chrysler recall, and said both relays should be replaced with dealer solid-state units; an aftermarket fan can also set the code.
