Backfire and Won't Respond to Gas Pedal
GCLEEHUSKER
My 2000 Dodge Grand Caravan 3.8L. 90K miles began cutting out after about ten minutes on the highway after filling up on the way to work. The car sputtered, hesitated and backfired if I tried to use the gas pedal, though it did finally catch enough at 55mph to make it to my work (about five miles later). When starting from a stop, the idle was rough and any pedal use would start to stall the van. Using little or no pedal gave me power until up to speed and then careful movement of the pedal got me to work. My computer shows no codes (code 55 repeated) and the service engine light is on. When started, the van still runs rough now and can backfire if the pedal is moved, but seems to be slighlty better (the pedal does rev the engine to high rpm while it sits in the parking lot). I did notice some small higher-pitched hum from the bottom middle or maybe further back of the vehicle at a stop a few days ago and was thinking about the fuel pump, but I cannot hear the noise now.
Jun 20, 2007 at 6:09 AM
BPRICE443
  • 66 POSTS
I would take the van to autozone or somewhere that will scan your ecm for codes. I would try changing your fuel filter to see if that helps since it happened right after you fueled up you may have sucked some dirt into your filter. Or maybe you got a bad tank of fuel??
Good Luck
Brian
Jun 29, 2007 at 7:01 PM
CHICKLET
Mine did the same thing, it was the fuel pump, but I got mine straight from Dodge place. Cost me 315.00 but well worth it. It runs fine now.
Jun 30, 2007 at 8:32 AM
