If I had bad rear wheel cylinders, would this cause my emergency brake lamp to be contsantly lit? If not, what might cause this?
Mar 14, 2006 at 10:08 AM
Check the parking brake switch. If the park brake does not hold well, inspect for badly worn brake shoes and check park brake linkage adjustment.
The owner of a 1999 Dodge Caravan asked whether bad rear wheel cylinders would keep the emergency brake lamp constantly lit, and what else could cause it. The expert said it sounds like a bad switch, and that poor park-brake holding could indicate worn brake shoes or a park brake linkage adjustment issue.
