1996 caravan brake fluid leaks!
HITMANX
hey good evening .. i currently have a 1996 dodge caravan .. i have a serious problem with the brake fluid it leaks out rapidly i noticed the leak coming from a small box or pump located on the left real side under the vehicle... so i would like to know what is the part`s name so i can replace it asap
Aug 19, 2007 at 4:54 PM
  • 75,988 POSTS
[quote:8fd293e880="hitmanx"]hey good evening .. i currently have a 1996 dodge caravan .. i have a serious problem with the brake fluid it leaks out rapidly i noticed the leak coming from a small box or pump located on the left real side under the vehicle... so i would like to know what is the part`s name so i can replace it asap[/quote:8fd293e880]
-sounds like the proportioning valve. do you see 2 brake lines going to it.
Aug 19, 2007 at 5:44 PM
  • 75,988 POSTS
You said Yes I do, I say You got it/Now go get it.
https://images.2carpros.com/forum/automotive_pictures/12900_donate_7.gif
Aug 19, 2007 at 7:59 PM
HITMANX
ok thanks a lot
Aug 20, 2007 at 5:06 AM
