1998 Dodge Caravan Brake Lights Fuse Blows
DODGELOVER
[b:cda9bc4c69]I am having a probelm with my 98 grand caravan, 144,000. the brake lights are not working. I honestly have no clue how long they havent worked but it hasnt been very long I just had an inspection done a month or so ago. The fuse keeps blowing as soon as you hit the brake pedal. My husband and I went through 7 fuses trying numerous things, it finally got to dark to see anymore and my huisband replaced everything and put yet another fuse in and it worked then today, 2 days later (hasnt moved since that night) I had my neighbor check b4 I left to see if they were working and it has blown another fuse. I dont know what could be causing it, and it is baffling my husband.[/b:cda9bc4c69]
Feb 9, 2006 at 4:09 AM
PEPPERMRJ
  • 1,158 POSTS
Don't you hate when that happens. :twisted:
Check the brake light switch, its connections, and wires. Might also be a short in the wire going back to the lights.
Good hunting and let us know.
Feb 12, 2006 at 3:50 AM
Suggested Repair
Check the brake light switch, its connections, and wiring, and inspect the wire running back to the brake lights for a short.
Conversation Summary
A 1998 Dodge Caravan with about 144,000 miles has brake lights that do not work because the fuse blows as soon as the brake pedal is pressed. Several fuses were replaced; the lights worked briefly, then another fuse blew two days later even though the vehicle had not been moved. The expert suggested checking the brake light switch, its connections and wires, and looking for a short in the wire going back to the lights.
