2007 Dodge Caravan Brake failure
33,000 MILES • 6 CYL • FWD • AUTOMATIC
TORTOREA
I had the van 2 weeks, had no problems. One night while in stop and go traffic and just cruising not driving, the van would not stop and I plowed into the Toyota Tundra in front of me. I assumed that I didn't apply the brake soon enough. $6000 damage to the front. However, I've had the van back only a week and 3 times now the van will not stop. Once the brake pedal seemed as though it was "bouncing" back, and this morning, no matter how hard I pressed I still sailed right through an intersection. The brakes are also squealing. Midas says all brakes and pads are perfect and need no maintenance. What's up?
Jan 29, 2009 at 12:05 AM
  • 110,248 POSTS
Hi:
From your description, it sounds like the ABS is kicking in and regardless of how hard you push the brakes, they refuse to respond. Did you purchase the van from a dealer? Also, at 33K the ABS is still under warranty. Considering it already caused a accident, and now it is happening again, a dealer should look at it and determine the problem (under warranty). Also, explain what you have gone through and if they can't be fixed, you want Chrysler involved. They get 3 chances to fix the problem. If they can't, it falls under the lemon law and Chrysler may have to replace it.
Let me know how it goes for you.
Feb 21, 2021 at 3:06 AM
