2005 Dodge Caravan front blower fan
RICHARD 17
  • 2005 DODGE CARAVAN
  • 6 CYL
  • 45,600 MILES
Front blower fan won't run, checked fuse, okay. Won't run in any position on switch
Tuesday, April 21st, 2009 AT 4:09 PM
BMRFIXIT
  • 19,053 POSTS
Locate blower motor and disconnect wire plug
turn key on place fan switch on high and check for power and for ground at the wire plug
if you have both replace blower motor
if no ground replace speed resister
if no power check fuses and wiring check ignition switch
good luck let me know
Tuesday, April 21st, 2009 AT 9:36 PM
