2001 Dodge Caravan blower motor
PETE G
Heater problem
2001 Dodge Caravan 6 cyl Front Wheel Drive 110000 miles
blower motor will not shut off this van has climate control with rear heater when you push the off button it seems to blow more
Feb 15, 2009 at 2:41 AM
JDL
  • 16,098 POSTS
Pull the fuses for the front and rear blower relays. That won't fix your problem,but it will keep the battery from running down. Fuse 10-40 amp, fuse 12-25 amp. It might be a stuck blower relay, I can't be sure. Pulling the relays will also kill the blower.
Feb 15, 2009 at 8:00 AM
