2003 Dodge Caravan Brake lights
97,000 MILES • 6 CYL • FWD • AUTOMATIC
RGOULDNER
I have no brake lights and have checked the fuse and replace the brake pedal switch to no avail. Whats the possibility that all three bulbs burnt at once (tail lights are fine)
Nov 11, 2008 at 1:13 PM
JAMES W.
  • 2,394 POSTS
It highly unlikely that all 3 lights would burn out at the same time, but they could one at a time over a period of time. And, if you're like me, how often do you actually check your brake lights? Bulbs have a life span and it almost seems like they have a timer in them. Like headlamps, you replace one and it seems like a week or two later, the other one goes out. I would check the bulbs, if they're good, check for power at the pedal switch. If no power there, double check your fuses. One last thing. When I'm out driving around, I see more Dodge vans with brake lights out than any other vehicle. I don't know why, but it's true.
Feb 27, 2021 at 5:49 AM
