2002 Dodge Caravan wont start after testing A/C clutch rela
JOEBEAR
  • 2002 DODGE CARAVAN
  • 6 CYL
  • 196,000 MILES
We swapped relays to test to see if the a/c relay was working then we went to start the car and now it just tuns and turns but never cranks. We are not getting any type of spark We have checked all fuses and everything seems fine. We got multiple codes from the computer but none seem that the would keep the van from starting P0123, P0118, P1193, and P1684, after trying a few things we also got P1388 for the ASD but the relay is good. We put a crank positioning sensor on as well. Any help to get the vehicle started would be great. Thank you
Wednesday, June 3rd, 2009 AT 12:25 PM
JDL
  • 16,098 POSTS
Hello, swap the relays back to original places, if you haven't already. Did you check the feed circuits to the asd relay? Terminals 30 and 86 show to be hot all the time. If that checks out, you can check that the computer is grounding the coil side of asd relay.
With the engine cranking is there any primary voltage to the coil, brown wire white tracer?
Wednesday, June 3rd, 2009 AT 12:46 PM
