Compressor leak
155,000 MILES • V6 • FWD • AUTOMATIC
CRAZYTOM
AC no longer cooling. Took to mechanic, who used UV to find leak in the compressor. Mechanic advising complete AC rebuild kit rather than simple compressor replacement, as concern is debris may have contaminated the system. Is this a reasonable conclusion? Vehicle has front and rear AC, putting complete rebuild at $1,800.00.
Jun 14, 2017 at 11:50 AM
CJ MEDEVAC
  • 11,000 POSTS
Just my opinion,
As long as the compressor did not lock up (which might scatter debris through the lines) and it was just a leak that made it non-functional,
I would just replace the compressor and evacuate the system with a vacuum pump.
I have seen many a junkyard compressor open to the atmosphere for a quite a while, be installed and work just fine.
Other folks on here may jump in with theirs.
The Medic
Jun 14, 2017 at 12:45 PM
  • 31,937 POSTS
I would go with a replacement compressor as well, if you get a second hand unit make sure that it is off a system that has not be open to the atmosphere for very long, if your system runs a receiver dryer get that replaced as well as this also acts as a filter for the system. Make sure that the system is vacuumed down and the correct amount of refrigerant is added this is very important for the system to work correctly.
Jun 16, 2017 at 7:43 PM
