2002 Dodge Caravan wont start after been driven for a littl
HOGS FISHING
  • 2002 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 88,000 MILES
Starts fine drive to store 5 or 6 miles away and wont start when get back in let set a few hrs and start fine battery new and checked out ok when it will not start you can not even jump start it today went to store to get battery checked out it checked out ok driving home it died and would not start when trying to start it noticed the relays clicking chanded out the safety enable relay for headlamp relay cranked up drove home got new relay installed it and would not crank
Tuesday, June 22nd, 2010 AT 1:49 PM
  • 109,772 POSTS
When it doesn't start, does the starter work? If it does, have you checked for spark and fuel to the engine?
Tuesday, June 22nd, 2010 AT 6:47 PM
HOGS FISHING
The starter dose not work the lights an radio come on but the starter dose nothing I can hear the relays clicking and the emerg shut down realy gets hot I switched the horn relay to that spot and the van started got me home I went to parts store and got a new relay in staled it and van would not start lights and radio come on but no action from starterremoved the battery put on charger and checked all wiring to starter and every ehere under the hood I could see and feel did not find any loose or other problems with wiring about 2 or 3 hours put battery back on and starts right up?
Wednesday, June 23rd, 2010 AT 2:34 PM
  • 109,772 POSTS
If it gets that hot, I question if the starter is drawing too much power.
Wednesday, June 23rd, 2010 AT 8:34 PM
HOGS FISHING
I carried it to the shop tuesday evening and left it. The van would not attempt to crank for them wednesday morning after checking it all out the mechanic said he thought it was the computer (brain) this was replaced under extended warinty in march of 2009, the machanic acted as if that was just a guess and was not sure what was wrong?
Thursday, June 24th, 2010 AT 8:32 AM
