The noise sounds like high presure fluid sounds.
2002 Dodge Caravan Steering Noise
Suggested Repair
Check power steering fluid level, turn the wheel lock to lock with the reservoir open to bleed air, and inspect the drive belts for cracks or looseness. If the noise continues after the pump, hoses, and steering rack have been replaced, replace the upper strut bearings, which corrected the same turning noise on a similar Caravan.
Conversation Summary
A 2002 Dodge Caravan makes a high-pressure fluid-like noise when the steering wheel is turned from center and again partway through the turn, in both directions, and the steering sometimes feels like it slips. An expert advised checking fluid level, bleeding air from the system, and inspecting the belts. Other owners reported the same issue after pump, hose, and rack replacement; one said replacing the upper strut bearings eliminated the noise.
