2002 Dodge Caravan
BOBROB24
  • 2002 DODGE CARAVAN
Noises problem
2002 Dodge Caravan 6 cyl Two Wheel Drive Automatic
Have a 2002 dodge caravan with a whining noise that sounds like a small vacumn leak but is not. It comes from the fuel pump module located on top of the gas tank. The car runs fine, no problems but this started 2 weeks back and is not going away. Car has 60,000 cream puff miles on it. Is this just an annoyance or is something heeded south on the pump itself? Thank you. Bob
Wednesday, July 21st, 2010 AT 8:54 AM
  • 109,885 POSTS
If it is coming from the top, make sure there are no fuel leaks. If everything looks good, chances are the fuel pump may be going. However, it could be like that for many miles. If the check engine light hasn't come on, then chances are there are no leaks in the EVAP system, so that is good.
Wednesday, July 21st, 2010 AT 10:45 PM
