2001 Dodge Caravan power steering
150,000 MILES • 6 CYL • FWD • AUTOMATIC
FRAMEDOCTOR
the power steering fluid sprayed out on the underside of van when i started it cold(Minnesota)
Dec 29, 2007 at 8:54 AM
  • 31,937 POSTS
Hi there,
You may have blown a power steering hoes, you will have to wash it down and fill the reservoir have someone start the cat while you watch for the leak. Your mechanic will be able to replace a hose if you feel your not able to do the job, If the hoses are ok and the leak is at the steering rack? box this is a job for your mechanic to do.
Mark (mhpautos)
Dec 29, 2007 at 9:42 AM
