I changed valve cover gaskets and discovered oil sludge in the cam and valve head assembly. Engine run well
Should I attempt to "flush" the engine or use a special high detergent oil or just keep changing oil and not worry about the sludgedge?
Apr 3, 2010 at 12:40 AM
